Kia Stinger GT 3.3 Twin Turbo 370 hp / 2.2 CRDI
Ce alte modele mai sunt şi ne interesează?
Moderator: BAU
rymin
Auto: Magentis VGT CRDI
Post by rymin » 03 May 2017, 17:43
Specificații și date tehnice
Motorizări
2.2l Diesel
Tip motor - 4 cilindrii in linie, diesel
Capacitate - 2,199 cc
Alezaj/ cursă - 85.4 x 96.0
Raport compresie - TBC
Putere maxima - 202 ps (149 kW) @ 3,800 rpm
Cuplu maxim - 441 Nm (325 lb ft) @ 1,750-2,750 rpm
Valve - 16 (4 per cilindru)
Sistem alimentare - CRDI (injecctie directa common-rail)
2.0 Benzină
Tip motor - Turbo, 4 cilindrii in linie, benzina
Capacitate - 1,998 cc
Alezaj/ cursă - 86.0 x 86.0
Raport compresie - 10.0:1
Putere maxima - 258 ps (193 kW) @ 6,200 rpm
Cuplu maxim - 353 Nm (260 lb ft) @ 1,400-4,000 rpm
Valve - 16 (four per cylinder)
Sistem alimentare - GDI (direct injection benzina)
3.3 Litri / 370 CP ‘Lambda II’ V6, benzină
Tip motor Twin-turbocharged V6
Capacitate 3,342 cc
Alezaj/ cursă 92.0 x 83.8
Raport compresie 10.0:1
Putere maxima 370 ps (276 kW) @ 6,000 rpm
Cuplu maxim 510 Nm (376 lb ft) @ 1,300-4,500 rpm
Valve 24 (f4 per cilindru)
Sistem alimentare GDI (injecție directă, benzină)
rymin
Re: Kia Stinger GT 3.3 Twin Turbo 370 hp / 2.2 CRDI
Post by rymin » 11 May 2017, 19:21
de vânzări va începe în Coreea din 23/05/2017
rymin
Post by rymin » 03 Jun 2017, 17:20
rymin
Post by rymin » 03 Jun 2017, 17:55
b76bgaarh
Post by b76bgaarh » 06 Jun 2017, 13:43
preturi de la noi nu ai?
masina mea Kia SPORTAGE 1,6 GDI style
masina prietenei Kia C'EED best 1,4l
Post by quelloo » 06 Jun 2017, 18:27
probabil de la 40000 incepe asta cu V6-le
rymin
Post by rymin » 07 Jun 2017, 17:51
Post by Ogy » 08 Aug 2017, 00:38
Garajul meu
b76bgaarh
Post by b76bgaarh » 03 Oct 2017, 14:06
Post by quelloo » 03 Oct 2017, 16:12
mda, concluzie: motor ok, dar nu prea, si cutie praf.
o marketeaza pe dotari si interior.
b76bgaarh
Post by b76bgaarh » 04 Oct 2017, 15:36
modelul 2.2 in franta.
b76bgaarh
Post by b76bgaarh » 09 Oct 2017, 10:27
pt cine intelege "germaneza"de bielefeld.
belghiru
Auto: C-Apostrophe-D SW LP
Post by belghiru » 27 Oct 2017, 23:22
C-Apostrophe-D SW 1,6 crdi piston grey
b76bgaarh
Post by b76bgaarh » 02 Nov 2017, 15:44
cica si "derapeaza".
GabiA
Auto: Kia Cee'd 1.4 2007
Post by GabiA » 02 Nov 2017, 21:59
Cee'd 1.4 best 2007 --> E neagra si e a mea! Jurnal de bord
Return to “...ce am omis?”
Who is online
