Pastile prentu cresterea cifrei octanice
bibiloi
gigi pedala
Post by bibiloi »
Ce stiti de ele? Am un prieten arab care le foloseste pe Logan si pe Peugeot206 automat, si la ambele odata cu cresterea cifrei octanice a scazut consumul si evident daca apesi in pedala mai tare sunt mai nervoase, adica sa ajungi la 99+ cifra octanica bagi 1 sau 2 pastile si iesi mai ieftin decat la pompa.
Kia Cee'd 1.4 BEST GSL Piston Gray - comanda pe 15 iunie, serie venita pe 3 septembrie, ridicata in data de 28-09-2007 ora 12.15 BT-04-EKV ex:B-71-KAO
manucu01
Post by manucu01 »
pai cat e o pastila? se foloseste o pastila la un plin?
Opel Mokka 4x4, 1.4l 140CP
bibiloi
gigi pedala
Post by bibiloi »
Prima data 2 pastile la plin si apoi cate 1, cu conditia sa nu ajugi cu 1 litru in benzinarie.
psystem
Geologu'
Post by psystem »
Si de unde se pot cumpara? Pretul?
Ce firma le produce? Par de incredere?
Daca ar fi bune iar pretul rezonabil(o pastila sa nu fie mai mult decat diferenta intre 95 si 99).
Bafta
Akbhar
Post by Akbhar »
http://www.carbibles.com/fuel_engine_bible_pg3.html
MPG Caps, FFI and all the other "pill in your fuel tank" miracle workers.
Status : Tested
mpg caps Websites : myffi.biz and mileagesecrets.com
MPG Caps, or any of the other "pill in your fuel tank" products are the cheapest and easiest-to-find miracle cures for increased power and gas mileage. The products are simple. They're normally pills, in a pop-out wrapper just like medical pills, or in a bottle. They smell foul and the manufacturers claim that one pill per 20 gallons of fuel will give you increased power and performance whilst at the same time cutting your mpg (in some cases they claim up to 30%). Explanations range from "organic engine conditioner that improves fuel economy and power by creating a micro-thin coating on the combustion chamber allowing fuel to burn better" all the way up to the fantastical "nanotechnology particles that seek out and change the molecular structure of refined gasoline to make it burn more efficiently". Wow. Impressive stuff, but as always, it's nonsense. Typically these pills are biodegradable plant or sugar compounds laced with food colouring and some odd petrochemical to give them an official smell. They don't work and are simply yet another scam to make you part from your money.
ABC reported on a AAA test of the MPG Caps and found their claims to be invalid.ABC report.
Texas recently closed down Bioperformance Inc. for fraud linked to their magic fuel pill: Report.
For my test of the MPG Caps fuel pills head over to my Product Reviews page.
On average, with the pill in the tank, we saw a drop in fuel economy by about 2mpg. There was no perceivable increase in acceleration or the ability to perform at-speed overtaking maneuvers. This pill is another scam. Don't bother with it.
Nenea asta spune ca solutiile astea miraculoase sunt mai mult placebo. There ain't no such thing as a free lunch
manucu01
Post by manucu01 »
buna informatie. click de la mine ptr asta :) http://www.colectionarul.com/Akbhar.html
psystem
Geologu'
Post by psystem »
Facem troc? :lool:
andrei0241
3/E
Post by andrei0241 »
Nu stiu cat de indicat e folosirea unei benzine cu cifra octanica mai mare, deoarece fiecarei cifre octanice ii corespund si alte proprietati ale carburantului: temperatura de ardere, timpul de ardere etc. Iar daca un motor este gandit sa functioneze cu un anumit tip de carburant, variatiile in jurul acelei valori sigur nu vor oferi performante optime
Plus ca o pastila care sa creasca cifra octanica, dar la pret sa fie mai ieftina decat diferenta de la pompa ... mie mi se pare cel putin dubios :D
bibiloi ... "evident" ala (si evident daca apesi in pedala mai tare sunt mai nervoase) ce inseamna? Ai condus masinile respective inainte si dupa aplicarea acestui "tratament" ?
Ford - Fiesta - 1.4 tdci
bogdan241
Post by bogdan241 »
exista pastile si pt cresterea muschilor...si nu sunt chiar sanatoase :D
cash
Post by cash »
si mai sunt unele pastile pentru cresterea unaor anumiti muschi cu care toti primim spam pe mail... :)))))
CEE'D 1,6 GSL BASE Piston Grey + 2-3 optionale;
poze: http://picasaweb.google.com/adrianstefa ... bilicaCeeD
jurnal de bord: viewtopic.php?f=5&t=2692
ODO 18000km
silviu41
Post by silviu41 »
MPG-CAPS TM este prezentat sub forma unor capsule care se introduc in rezervorul masinii. Folosirea capsulei duce la scaderea consumului si la imbunatatirea performatelor motorului. MPG-CAPS TM vine cu o tehnologie revolutionara , perfecta atat pentru motoarele pe benzina cat si pentru cele pe motorina. Substanta activa prezenta in MPG-CAPS TM este rodul cercetarilor specialistilor de la NASA si a fost folosita, pana de curand, exclusiv pentru imbunatatirea performantei motoarelor racheta. De curand produsul a capatat acceptul de a fi comercializat.
Acest produs este fabricat in SUA, statul Florida, iar compania se numeste Fuel Freedom International, Inc . Pe data de 9 septembrie 2006 a patruns oficial si pe piata europeana, fiind prezentat in Anglia.
MPG-CAPS TM este un catalizator unic compus din substante active 100%. Astfel atat la motoarele cu benzina cat si la cele diesel, mareste puterea motorului, scade consumul si reduce emisia noxelor. MPG-CAPS TM este si un ?nlocuitor al plumbului. ?n afara de acest fapt, asigura o ungere mai buna a motorului si reduce emisia de fum. Mai mult de atat, folosirea produsului MPG-CAPS TM creste durata de viata a motorului si scade cheltuielile de intretinere.
Efectele benefice asupra motoarelor cu benzina:
- reduce consumul de carburant cu peste 10%;
- ridica performantele motorului;
- creste cifra octanica;
- reduce zgomotul motorului;
- preia rolul plumbului;
- reduce depunerea funinginii;
- prelungeste viata bujiilor;
- reduce emisia de gaze poluante.
Efectele benefice asupra motoarelor diesel:
- reduce consumul de carburant;
- mareste puterea motorului;
- reduce cantitatea fumului de esapament;
- creste durata de functionare a motorului;
- reduce timpul de ?ntretinere.
Eu folosesc si sunt multumit de rezultat.
CRDI 1,6 / 90 piele pe vplan si schimbator, scaun sofer reglabil pe inaltime si lombar, faruri de ceata... mama ce misto e!
http://www.hi5.com/friend/photos/displa ... =199161478
cash
Post by cash »
de-aia inchid aia toate firmele producatoare de asa ceva din SUA :))))...hihi
ODO 18000km
Arnold12
Post by Arnold12 »
Un link ceva sa vedem si noi de unde ai informatia?
cash
Post by cash »
Daca ma intrebai pe mine ... citeste tot postul lui Akhbar (al 5-lea de pe pagina asta). Acolo scrie de un caz clar din State in care au inchis o firma de-asta.
ODO 18000km
Arnold12
Post by Arnold12 »
Credeam ca ai gasit alt articol si eram curios.
