Am nevoie de info privind rotile de 17" si alte marunti
Am ESP la masina si am reusit sa plec si cu "scart",sa inteleg ca nu are acel TCS? Va rog sa ma lamuriti cu o problema,si anume:
care este diferenta intre 205/55/R16 6.0J si 205/55/R16 7.0Jsau7.5J?
Eu am comandat jante pe 16 dar din otel(nu stiu ce a fost in capul meu),iar acum vreau sa-mi iau de aliaj.
Va multumesc anticipat!
Ce este postat mai sus reprezinta descrierea ESP-ului din manualul de reparatii al lui CEE'D 1,4 benzina.GOvidiu wrote:Hai sa mai rezolvam o problema.
Cee'd [ED] > 2007 > Engine > 1.4 G
ESP system includes ABS/EBD, TCS and AYC (Active yaw control) function.
ABS/EBD function : The ECU changes the active sensor signal (current shift) coming from the four wheel sensors to
the square waveform.By using the input of above signals, the ECU calculates the vehicle speed and the
acceleration & deceleration of the four wheels.And, the ECU judges whether the ABS/EBD should be actuated or
not.
TCS function prevents the wheel slip of drive direction by adding the brake pressure and engine torque reduction
via CAN communication.TCS function uses the wheel speed sensor signal to determine the wheel slip as far as
ABS function.
AYC function prevents unstable maneuver of the vehicle. To determine the vehicle maneuver, AYC function uses
the maneuver sensor signals(Yaw Rate Sensor, Lateral Acceleration Sensor, Steering Wheel Angle Sensor).If
vehicle maneuver is unstable (Over Steer or Under Steer), AYC function applies the brake pressure on certain wheel, and send engine torque reduction signal by CAN.
Ei spun ca ESP are inclus ABS/EBD, TCS and AYC (Active yaw control) function.
Voi credeti ce vreti, dar daca se mai continua discutia s-ar putea sa ajungem la o polemica gen cureaua de distributie care pana la urma s-a dovedit a fi lant (conform aceluiasi manual de reparatii)
Dauna totala 2010
Dauna totala 2010
bine,bine dar eu vreau sa stiu daca afecteaza cu ceva trenul de rulare daca iau cu 7J sau 7.5J avand in vedere ca din fabrica sunt cu 6J,iar ce jante imi plac (OZ) sunt cu min 7J;sau daca apare vreo problema legata de cauciucuriDennis wrote:@dario: 6J, 7J, etc. se refera la latimea jantei.
Ex:Cee'd 1.4 Machine Silver+optionale
Hyundai I30 1.4 140cp 6mt
cernicapoli
andrei0241
- 3/E
Distanta intre prezoane este aceeasi la Ceed si este 5x114,30x67,10.
KIA C'eed 1,6 CRDI XR 115 CP Dakar Yellow - http://www.turatii.ro
ISUZU D-Max 2,5l DSL 136 CP Imperial Blond - http://www.4balls.ro
eventual uita te la masurile celor de 17" care vin on dotarile optionale..
daca iti iei jantele la aceleasi dimensiuni ca acolo...nu are cum sa nu se potriveasca
si asta e valabil si pt cauciucuri
la cele de 17" zice asa 225/45/ 17w...
Ex: Ceed 1.4 Best, Kompass Blue
Ex: Subaru Impreza 2.0S, Pearl White
Now: Subaru Impreza WRX STI 2.5T, Rally Blue & Ceed 1.4 City
Re: Am nevoie de info privind rotile de 17" si alte mar
[quote="turatii"]
ET si distanta intre prezoane la Kia Ceed (nu radeti, dealerii nu stiu sa spuna), .[/quote
Am gasit pe un site "ceva" despre aceste informatii, au si configurator de jante de Al pentru Ceed incepand cu R15 pana la R18.
Se intra pe sigemo.ro si acolo la configurator jante pe rial.ro .... kia.... ceed .... si ai cam toate cotele pe fiecare dimensiune de janta ( ce vand ei = normal) inclusiv cu poze cum arata fiecare model de janta pe ceed.
PS .. nu e reclama dar sunt ... bine documentati baietii.
CEED "neagra" 1.4
filtru K&N - 109,99 CP
ODO 120.000 km
ODO 120.000 km
alexcercel
- Moderator
Un alt configurator: http://IceUrl.com/CeedRims
DAR ce e ciudat la asta e ca da jante de 17" cu ET 38 pt. Cee'd...
alexcercel
- Moderator
jante aftermarket Cee'd
si care configurator (Rial) arata asa:
http://img504.imageshack.us/img504/3897 ... ialrs7.jpg
f. interesant si util... iti ofera si dimensiunile de pneuri... si ce mai vrei acolo... TUV, norme UE...
