Descriere tipuri de alarma instalata, functii, probleme
Postati numai ce tip de alarma ati instalat pe ce versiune dotare masina, functiile alarmei instalate pe masina, descrieti ce funcii nu functioneaza si de ce.
Consider ca este util acest topic pentru a veni in ajutorul celor care doresc sa instaleze alarma si sunt total dezorientati si gresit informati de la dealer pina la mecanici, astfel pot sa se informeze mai usor ce tip de alarma sa achizitioneze, de ce sa tina cont la instalarea alarmei, alegerea alarmei compatibile pentru Kia si problemele aparute, multi doresc sa-si instaleze alarma si nu stiu ce tip de alarma ar fi mai buna pentru modelul respectiv. Rugaminte scurt si la subiect.
"Black Thunder cu R U G I N A" ODO--> 76000km
CEE'D 1.4 GSL Lx MT BEST 'Black Pearl' SM 89 LVN
Am dat comanda la o alarma model 2007 si astept sa o primesc.
ALARM, REMOTE START, AND KEYLESS ENTRY SYSTEM!
2 x 2 LCD REMOTES INCLUDED
The unit is equipped with an Ultra-Low Temperature Crystal and is designed to operate in temperatures around -40C ! No other unit on ebay for this price can claim that ! Most of them fail to work on those cold mornings, when you need it most. This alarm was designed to work in Russia and Norway, the coldest regions on Earth!
This system will work on all passanger cars, vans and MPVs with automatic AND manual transmissions, diesel or petrol
Remote Keyless Entry, Alarm Pager & Remote Starter functions
ALARM FEATURES
Adjustable Shock Sensor
The shock sensor's sensitivity is fully adjustable. No more false alarms in a thunderstorm.
Code Hopping
This system uses code hopping technology to increase the security of the alarm. Using this technology will prevent anyone accessing your system with the reproduction of your remote signal by grabbing or scanning.
Smart LED Indicator
The LED will flash the same number of times as you would press the lock button. (with-in 5 second after you arm your car.)
Door Status Warning
The parking lights will flash to inform you that one of the doors is notclosed. In case where you temporarily park, such flashing may warn incoming cars.
Status Memory
In case when the system lost power, the system will remember the status before it goes off, when power restore the system will come online a the same state as before it lost power.
Turbo Mode
For cars equipped with a turbo engine. In this mode the engine will continue running for 2 minutes after the key is pulled off the ignition. This will provide a gradual idle cooldown and will significantly extend engine life.
Remote Start
In this mode, your engine will run for 10 (default) minutes then shut off automatically after that. You may also kill the engine remotely within these 10 minutes.
Valet Mode
The system works just as a keyless entry without any security function. You can use remote for locking & unlocking door, trunk release and car finding.
Standard Arming Mode
When armed, doors will be locked. System will also remind you to arm your car 20 seconds after the key is removed form the ignition and all doors are closed.
Panic Mode
Anti-Robbery - Anti-Jacking - Alarm sets off and parking lights flash for 16 seconds and then the engine will shut off even if key is in the ignition. The system cuts power off at the distributor therefore the car will not be started again until panic mode is existed.
Multiple signal detection for remote start
Tach, High-Voltage & Oil sensor
Alarm Monitoring
Once armed, the alarm will monitor the Shock sensor, Doors, Ignition, Boot and any optional sensor such as ultrasonic (not included). If triggered, the siren will sound and the remote will beep and show the triggered area as a blinking icon (see picture above).
Six-tone 120db siren
Compatibility
This alarm works with factory security & remote entry systems. The remote can be used with or to replace your factory remote.
Mai multe informatii dupa instalare.
ALARM FEATURES
Code Hopping
Smart LED Indicator
Door Status Warning
Status Memory
Turbo Mode
Remote Start
Valet Mode
Panic Mode
Alarm Monitoring
Compatibility
- 3/E
Aata timp cat topicul se mentine doar la post'uri precum cel al lui Arnold12, acest topic va fi util. Rog insa pe toti sa se abtina de a a face alte comentarii, locul acestora fiind aici
Ford - Fiesta - 1.4 tdci
Maat 679 ... se merita ?
Mi-a venit masina si as vrea sa pun o alarma Maat 679 pe ea.
Din cei care mai aveti asa ceva ... ati avut probleme cu ea? se merita sa puna pe masina ? sau ce recomandari aveti ?
eu am pe masina, este simpla, acopera functia de baza, pana acum a functionat OK
www.erepublik.com
www.erepublik.com
- born on 13th
si eu am, montata la mit in baneasa. e intradevar simplista. m-au taxat baietii cu 500 de lei, da cu 1 zi inainte imi furasera bateria de la dacie asa ca am aceptat pe loc. singura chestie pe care o fac in plus cand activez alarma e sa dezactivez primul senzor de soc (tasta ARM/PANIC urmata de tasta FINDER/HIJACK), asta pentru ca pe frig urla cam din senin.
cee'd best 1.4 dakar yellow
B 73 WXX
consum mediu 6,7 % - 12.000 km
B 73 WXX
daca tii masina langa bloc ..la vedere...sau in garaj..nu ti trebuie mai mult...ah si daca nu ai fitze de genu sa porneasca motoru inainte sau sa se inchida geamul cand inchizi din telecomanda masina...
daca esti in situatia mea..sa parchezi la 3 blocuri distanta..e bun sa ai si un pager...si o alarma mai completa..
Ex: Ceed 1.4 Best, Kompass Blue
Ex: Subaru Impreza 2.0S, Pearl White
Now: Subaru Impreza WRX STI 2.5T, Rally Blue & Ceed 1.4 City
Viper 350 HV-cumparata si montata la Falcon 5 mil-nicio problema (o am doar de 2 zile
•Protejarea transmisiei radio dintre telecomand? ?i masin? prin tehnologie Clone-Safe™ (Imposibil de reprodus)
•Anularea declan??rii sistemului de securitate nu duce la deschiderea u?ilor - High Security Disarm
•Sunete de confirmare nederanjante Soft Chirp®
•Imposibilitatea pornirii motorului cu sistemul armat - Failsafe® Starter Kill
•Armare sistem din telecomand? dar ?i automat? (pasiv?)
•Avertizare ?i declan?are la ?oc (prin senzorul de ?oc Stinger® DoubleGuard®)
•Anulare momentan? a sistemului din telecomand? Remote Valet
•Armare automat? chiar cu un circuit uitat deschis
•Imposibilitatea pornirii motorului de str?ini chiar ?i dup? dezarmare - Automatic Engine Disable (AED)
•Sunet usor de recunoscut – Sirena cu personalizare Revenger®
•Prevenire ?ncercare de furt – Preavertizare (Warn Away®)
•Diagnostic prin LED-ul de stare
•Eliminare electronic? a alarmelor false – Nuisance Prevention® Circuitry (NPC™)
•Armare dezarmare f?r? sunete - Silent Mode™
•Protec?ie personal? ?n mers prin ?ncuierea-descuierea u?ilor comandat? de contactul cheie
•Confirmare optic? la armare/dezarmare
•Deschiderea accidentala a u?ii declanseaz? progresiv sistemul permitand dezarmarea inainte ca acesta sa devina o sursa zgomot -Progresive Door Trigger
•Atragerea aten?iei asupra vehiculului ?n cazul unui atac la persoan? – “Panic?”
( folosit ?i pentru localizarea vehiculului ?n parcare )
Oricare din sistemele de securitate sofisticate Viper ESP este programabil cu PC sau Bitwriter™(un scanner portabil) ?i ofera urm?toarele func?ii personalizabile:
•Recunoa?tere proprietar: Vehiculul va recunoa?te la dezarmare/armare ?i se configureaz? ?n concordan??, prin set?ri personalizate pentru maxim 4 ?oferi.
•Telecomenzi cu pictograme: Pute?i comanda sistemul la armare/dezarmare din butoane separate sau din acela?i buton – alegerea v? apartine!
•Canal suplimentar adaptabil FlexChannel™: Un canal suplimentar ce poate fi configurat s? comande orice accesoriu de confort sau siguran?? (deschiderea geamurilor, ?nchidere trap?, etc).
•Anulare senzori din telecomand? - Remote Zone Out™: Permite s? anula?i temporar, din telecomand?, oricare sau to?i senzorii sistemului precum ?i oricare alt? zona protejat? a vehiculului (capot?, u?i, etc.)
La masina ta inafara de inchis deschis mai face si altceva? (deschiderea geamurilor, ?nchidere trap?, etc...)
pe langa inchis,deschis usile se mai pot monta diverse module dar eu nu am vrut:
Module suplimentare:
Siren? back-up multiton 515R - 40 USD (se va achita numai diferen?a de 22 USD dintre aceasta ?i sirena multiton din configura?ia standard);
Senzor perimetru dubl? zon? 508D (interior - declan?are, exterior - preavertizare) - 46 USD;
Senzor audio 506T(declansare a sistemului la o tentativa de spargere a geamului) - 19 USD.
Senzor antitractare - miscare omnidirec?ional 507T (declan?eaz? sistemul la orice ?nclinare a ma?inii mai mare de 2 grade) - 46 USD;
Indicator electroluminiscent „VIPER” 620V– 19 USD
Modul ridicare geamuri 528T – 14 USD(pentru masinile de provenienta germana)
Interfata inchidere centralizata 451M – 9 USD(455J – 49 USD)
Mersi @Misu dar macar atunci cind te apropi de masina si o dezarmezi se aprind farurile sa vezi drumul pina la ea sau si pt asta iti trebuie modul?
La viper nu necesita module
Aprinderea farurilor din telecomand?
Lumineaz? drumul de la / p?n? la ma?in? ?i permite localizarea ma?inii pe ?ntuneric.
Descuierea cu prioritate a u?ii ?oferului
Previne tentativele de jaf ?n parcare, descuind doar u?a ?oferului la o simpl? ap?sare de buton.
scuze de intarziere dar am facut rodajul
alarma nu aprinde si farurile-doar "clipoceste" semnalizarea
pe mine oricum ma interesa o alarma simpla care sa-mi protejeze cat de cat masina. faza e ca orice alarma ar avea, tot ti-o fura daca e. mai mult am pus alarma pt descurajare si pentru deschiderea centralizata
